westman995 10+ year member
Ok so im pretty sure im gona build a custom box for the rear of my 82 Trans Am. I got two DD 1508s on their way to me. So i am wondering what is the absolute best box size for the 1508? I want to get maximum output and really surprise some people with these little things. I should have more than enough room to go ported with these little subs, i would image. I think i got under 3 cubes to work with in my area, so should be enough i think.
Another question is, Is there any calculators or sometihng out there where i can easily change like the heighth of the box to make it the correct volume, or how do i got about figuring out exactly what height to make it to get the right volume?
This is kind of like what the box will look like to go in the rear "well" area thing.. I was planning to do this for two 12s but decided no way in hell i can get enough cubes in that area for the two 12s. It should be real similar to this minus the top being bigger than the bottom, and maybe not quite as high due to not needing as much space with the 8s. The box was not drawn to spec, its much deeper than it really can be, was just drawn to show idea of the shape it would have been.
So more than likely ill be trimming the height off that box, and the top wont be quite as big like i said, cuz that was to fit some 12s.
Can you recomend a box calculator that you can figure out what size to make it to get the right volume?
I read that .9 cubes ported some guy hit almost 150 with a single 8.. Now would that be .9 cubes before or after sub and port displacement?
I am also going to do slot ports im pretty sure.
One more question, since im doing two subs. Do i want to put a divider between the subs and put a port on each sub, or just build one big box with no divider and only one port? Im thinking with a divider is the way to go, but dono for sure.
