Battery hidden/big 3 help
  • 6
arthurk
So on my car, the battery is hidden up under the wheel well and then the wires go to two posts under the hood and everything is hooked to those. I already have 2 Kinetic Hc 2400's for the trunk and am wanting to replace the stock battery up front with another Kinetic and do the Big 3. My question is, don't I also need to run 1/0 to the hidden battery to those posts under the hood?
See the yellow positive sign is where everything is hooked up and then behing the cold air intake on the strut tower is the negative. There are wires going from each of these to the battery, which is hidden under the wheel well. Do I need to replace THAT wire with 1/0 gauge?
difference?
A short ram intake usually sits where the factory air box sat. It is also known as a warm air intake. A cold air intake usualy goes down into the fender, between the bumper and one of the front wheels. There, the temperature of the air is much cooler as it is not affected by the heat of the engine.
geeez, you're about to have 3 hc 2400's? how is your alt? you better have a big alt for all those batts home boy
Also, the front battery isn't a 2400 because they are way too big to fit up under there. Probably be a 1800 or smaller. I Have to see what will fit.
arthurk
arthurk
Indianapolis
arthurk
