Battery - Alternator HELP
sorry. just wait a little bit, see if it goes away. the alternator has the same plug as your stock one does, right? If it doesn't after a couple days you may need to go into the auto parts store and have them put it on a scan tool to clear the code.
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
I'm not an expert on Lithium by any means. All I can say is I've played my system for about 2 hours at about half volume(20/36 on the headunit)...
8
cbuts
cbuts
canada,ont
cbuts
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
