Battery - Alternator HELP
cbuts
just installed my 275A singer alternator, took off the small pulley that came with it and used the bigger one that also came with it and my stock belt.
install went fine, except my voltage isnt right.
when im driving it reads 14.9, but when i stop at a light it goes straight to 13, and slowly decreases to about 12.4
also when in park it sits around 13ish
PLEASE HELP.
battery is a new red top that i bought the other day, and it reads 12.7 when engine is off. light wasnt on before alternator upgrade, and new battery was put in prior with no problems
vid of alternator running,seems to be very hot too
https://www.dropbox.com/s/sx7bcxmxijgxkjd/VIDEO0058.mp4
What car do you have? And why did you take off the small pulley that came with it? If you use the larger pulley, the alt will spin slower, and possibly make it shut down when your engine is running slower. Which is what you're seeing.
i didnt have a smaller belt at the time, its an 06 malibu 3.5l
yeah i guess ill have to try that... but what if it dosnt work.. lol
thx for the posts
Well then go from there. If it's not that, chances are it's your car. Were you monitoring voltage before you put the alt in? Did it do this?
I'd bet it's the pulley though.
not the pulley ...its the car ..before i externally regulated my impala ..it would drop to 12.9 its computer controlled u will have to externally regulate it to keep 14.4 or higher
no everything was completely fine before the install, and after starts up fine, i notice my voltage sitting at 14.8 from what it was before like 14.2 and then after a minute i noticed battery light on, and voltage now sits around 13 when idling in park, and goes down to 12.4 while at a stoplight(no accessories)
i really hope your right with the pulley, this is really bugging me, i hope i dont have trouble finding one
So you install the alternator incorrectly then wonder why it doesn't work...
elaborate?
---------- Post added at 09:44 PM ---------- Previous post was at 09:43 PM ----------
where would i find an external regulate?
elaborate?
I revised my post, I just meant the alternator was designed to produce output at certain RPM's and by changing the pulley to a larger one you slow down the alt and probably decreased it's output.
Bad news bears right there.
He said it wasn't doing that before though. Are these the same models? Yours is 2 years newer so it's possible they updated the computer in that timeframe. I don't know either way though.
Okay, i just figured it came with a big one so why not try it.. my 110 stock alt idled and drove around 14 v and dropped 13.5 when bass hit, if i change the pulley will this idle like its supposed to..
nasty thinks otherwise.. really mind boggling and FRUSTRATING
elaborate?
i have a transpo bout 125 bucks ..
---------- Post added at 10:48 PM ---------- Previous post was at 10:48 PM ----------
elaborate?
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
I'm not an expert on Lithium by any means. All I can say is I've played my system for about 2 hours at about half volume(20/36 on the headunit)...
8
cbuts
cbuts
canada,ont
cbuts
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
