bat terminals
  • 5
You dont NEED them but they make things look nicer imo. You can just put ring terminals at end of your wire and bolt it to your stock batt terminals.
I've used the KonFused terminals in my last two projects. Nice terminals in my opinion.
The Knu terminals you linked will probably do just as well...
oh okay..so something like that is just as good as what I posted? hopefully so...then i wont have to spend the 12 dollars for that
Ya its all the same //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Just some look nicer thats all.
so how would I connect my 4 gauge wire that runs from the bat to fuse all the way through the car to amp etc..and hook up the 0 gauge to the bat as well for the big 3?
I did it on my ladys and used her stock battery terminals..
Just bolt them to your stock batt terminals like I did on my ladys..
yeah but where is your wire running from the fuse to bat to amp? dont see a fuse at all..thats what im worried about using 4 gauge for everything else except big 3..I dont see how I can combine them both on the battery.
if that makes any sense..
Wire is wire, You can bolt the 4gauge and 0 gauge right next to each other lol its not going to make a difference lol and heres a better picture of the fuse.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can bolt 4 /6 /8 or 1/0 gauge on the same bolt it dont matter as long as it all fits. Just use ring terminals and your good to go!
ah okay..where did you get those wire covers from? not sure if thats what they are called. (the black/pink stuff thats around the wire)
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
717
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
ccab
For The Horde!
ccab
Southern Georgia
GetLikeMe
    May 18, 2024
    May 18, 2024
