Backup Camera: Factory Tailgate to Mirror / Factory Tailgate to Aftermarket Radio
  • 2
bwt20racer
Hello all!
I have a 2012 Chevy 2500HD Crewcab. There is a backup camera mounted in the tailgate that shows on my rearview mirror when I put it in reverse. I have an aftermarket radio (Kenwood DNX890HD) that I am wanting to show the stock reverse camera onto the screen of the aftermarket radio (or on both the mirror and aftermarket radio at the same time).
Thanks in advance for any help!!
~ Jeff
Just split the signal coming from the camera and run the second signal to the reverse camera hook up on the back of your new head unit
Use a RCA splitter.
Then just do everything needed to hook up the reverse camera but if all your wondering is how to get it to run to both then an RCA Y jack should be all you need.
This is all assuming that there is an RCA connector somewhere in the line. if there isn't it would almost not be worth it
I don't have a ton of experience doing back up cameras but I have hooked up a bunch of CCTV security cameras which are basically the same thing.
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
You will definitely want to read what the Reverse wire does, and what those two blue wires by the rear camera video input do. That should tell you...
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
It only works when the car is in reverse. Also, some units have trigger options in the settings menu.
545
How positive are you that the reverse camera power supply was spliced in with a reverse light wire? If you used one of those blue wire splicers...
bwt20racer
bwt20racer
Victoria, TX
Kickstand
    May 12, 2024
Brendon Jenness
    May 11, 2024
