audiopipe APSM 1300 for JL Sub
Do you have a suggestion for something that would be better around the same price. like around 120. And what do you mean by clean power.
i have used the apsm1300, and at a 4ohm load you just do just fine. or you could step up to the apsm1500, i think there are some for sale in the classies. clean power is unclipped/undistorted power. if gains are set properly and not maxing out, and never ever use the bass boost, you should be fine.
FYI I wanted to point out we have this amp available for about $105, not sure where you were getting it but I saw you had mentioned the $120.
If I were you OP I'd get a nice 2 or 4 channel and bridge it to give it what you want. That way when you upgrade you've got a good amp for your doors.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Do you still have this? Where are you located?
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
Also if you did decide to get another amp the output rca on the amp can be adjusted with the internal dsp
osupur8800
osupur8800
Ohio
DoesDad
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
