Amp Hz settings
  • 1
Rockguy475
houston
Have a JLHD900/5 coming back to me tomorrow and it will be powering my whole system. Everything is listed in my sig. I really am not too sure on how to set the Hz for my front and rear channels. I know my headunit has these functions as well... whats the difference between setting your system settings on your headunit vs your amp? Should i make use of the LPF and HPF? Im sure this is a noob question but it is all confusing to me. They have a few car audio shops around but I would rather not have to go pay for this but will if this is something I should not do myself.
The switch goes between the speaker and crossover.
43
4K
set your gain right, heres how. test tones are at the very bottom...
6
You will need a multi-meter, a set of RCAs that will be sacrificed, and a small blade screwdriver. First disconnect the amp from the LC2i. Now cut...
Thanks for the info, made the setting changes and that did the trick. Toyed with the amp gain to get the amplitude balanced out, then tweaked...
4
Rockguy475
Rockguy475
houston
Rockguy475
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
