Audio Set-up question
  • 3
I am new to car system audio. I am not new to wiring.
I have HU is 50Wx4 with 4 small speakers that can handle up to 300w.
I also have one 12 inch sub that has 175W RMS, max 500W.
I am debating on purchasing an amplifier that is a 400W 2 channel amp.
I have my speakers wired directly to my head unit. If I connect my amp and my 12inch sub to my HU, will I ruin my smaller speakers? Or, since the speakers are wired directly to my HU, will they not be affected by the amp? I do not want to blow my small speakers!!
OK, next question...
I acquired an 8 inch sub as well, but it is 8omh.
I want to hook my 12 inch sub and my 8 inch sub to my amp.
Amp specs: 400w, RMS rating: 4ohm; 50w x 2 chan;-- 2 ohm: 75w x 2 chan;-- Bridged, 4 ohm: 150w x 1 chan
Sub specs: 12 inch: 175 RMS at 4 ohm
8 inch: 120 RMS at 8 ohm
Am i able to hook these 2 subs up to the amp without frying it? And what sequence would I have to wire the subs if I can?
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
192
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
jbarnesiii88
jbarnesiii88
Bethlehem, PA
mylows10
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
