Audio Anarchy T-Line Demo Truck.... an Impromptu Video
  • 3
bbeljefe
I posted this video in the Amp Test Tuesday section of SMD because this week he'll be testing a CT Sounds 1400.1 and since I'm a CT Sounds dealer and, am running two CT Sounds 1400.1s, I decided to go ahead and make a vid even though the build is far from being done.
The subs are Sundown Zv3 15s but will eventually be CT Sounds Exos or better.
Lemme know what you think so far!
So sorry for the late reply guys. I've been busy as hell and didn't think to check back in to this thread.
The 1400.1s can be had in a shop for ~$350.00 and according to Steve Meade's amp dyno, the one he tested did ~1864 watts at 12.8 volts and 1Ω and ~2406 watts at 14.5 volts and 1Ω. You can watch the test
And thanks for the kind words. It's a work in progress that will end up with two Exos and a lot more power.
A Link would be very helpful. Id be interested in taking a look at some gear
200
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
326
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
bbeljefe
bbeljefe
Shreveport, LA
bbeljefe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
