Aq2200 no power to sub
  • 2
polen21
Looking for help regarding why I am not getting power to my sub. The aq2200 is brand new. Everything is connected properly. I am getting 12.2 volts into the amp. Power light is green. But I'm not getting anything to the sub. Any help on this would be great.
DO u have rcas plugged into amp? (i did that once) speakers wires plugged into correct outputs? does hu have sub volume and is rca plugged into sub output or to rear out put if so check sub volume or fader
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
535
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
725
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
556
polen21
polen21
Springfield il
polen21
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
