Another work of art by CSCStang...
k5james
Yuma, AZ
Because of some size restrictions I put on myself in the new build I'm going to start I was limited to 8s. I hit up CSCStang with my dimensions and asked him to try and make a Tline for two Sundown SA8v3s work and he worked his magic and was able to make it work...
I can't comment on the sound yet as I'm still waiting for some install pieces to arrive and need to make room in my workshop for the build but the quality of his work for the money can't be beat IMHO.
That sucker is gonna pound...people gonna think you got a pair of 12's or something if you got enough power. Chris designed my t-line as well for a single 8. What's vehicle it going into?
2013 BMW X5 diesel. It should be stealthy as hell too. I plan on putting it under here...
in this cavity...
It'll fit in there? Hope you plan to make a large opening or something to let the bass thru...
It's a tight fit but it fits. There should be enough gaps for the air to get out as it's not air tight. If not I'll cut a big hole and have a grill built for the hole.
Just wondering how far away the subs/port are from the wall compartment?
I ask with upmost respect because I think your gonna have issues "blocking" sound/bass inside that area. Might be an idea to create a big baffle out of wood and grille cloth and still use the space above. If that door is removeable.
gorgeous but man that's huge for 8's.. don't think i've seen a tline with port that big (or if i did i didn't know it was a tline)
you are too used to your "labrynth" enclosures... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Thats standard size for T line, maybe a bit too small to be honest, but he is space restricted.
You can read right?
I like different and this with that placement surely will be. Please keep us updated. I would have never thought of 2-8's in a tline. Probably would have went single 15 using that extra space under the rear deck as air space and doing a flush false floor.
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
747
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
k5james
k5james
Yuma, AZ
Papermaker85
    May 24, 2024
    May 23, 2024
