Amp settings
  • 3
Smurfy76
CarAudio.com Recruit
52
23
Florida
So I installed 4 audiopipe APMB-638SB-C. My question is should I have my amp at high pass or full? I plan on installing a second amp once I can change out the fuses on it (taramps solders on the fuses) so I will have a 400 and a 440 to power all 4 speakers. Most likely the 400 for the back and the 440 for the front. Also if it helps I do have a Clarion EQ installed as well.
Ideally you'd have a variable crossover, the taramp crossovers are set at 90hz. I'd probably use HPF with that for sure and then use another HPF from the Clarion unit settings, whichever sounds the best on sweeps. Not EQ, it should be a separate option. This mostly comes down to how it sounds and what your other speakers are currently handling. If you've got a subwoofer that plays loud and crystal clear at 250hz the answer will be different than loud and muddy above 80hz. The goal is to have a crossover that transitions between frequencies without the location or volume of the noise dramatically changing. This also depends on whether you get rattling at any frequencies with them. A well deadened surround will allow lower frequencies.
The switch goes between the speaker and crossover.
43
4K
set your gain right, heres how. test tones are at the very bottom...
6
You will need a multi-meter, a set of RCAs that will be sacrificed, and a small blade screwdriver. First disconnect the amp from the LC2i. Now cut...
Thanks for the info, made the setting changes and that did the trick. Toyed with the amp gain to get the amplitude balanced out, then tweaked...
4
Smurfy76
Smurfy76
Florida
AsisTOCI
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
