Amp not playing full volume first few minutes its turned on
  • 5
sirmalcs
SC
When I crank my car up my amp comes on but plays at 10% volume for first few minutes then randomly will kick up to normal set volume. Amp's power light is on, all wired connections double checked and good. (Note) I have the sound input running through an external high level output converter. Now the weird thing, if I ground the high level speaker wires for a second the amp kicks right into normal playing and will continue to play from that point on with no volume issues.
sounds like a bad converter to me.
and this is why LOCs are the worst way to go signal wise.
People area saying with newer vehicles that HU are dam near impossible to replace because of all the extra BS that's intregated within the HU and steering wheel controls.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
76
6
325
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
638
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
469
sirmalcs
sirmalcs
SC
los33
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
