amp interfering with radio
  • 1
jdeezy410
just wondering if there is any way that an amp could interfere with radio frequencies? i have a rockford fosgate t1500-1tb amp pushing t 12 inch spl splw12's and whenever i kick the amp on from my remote it drowns the radio to sound like water being pushed through the speakers. its ran in a 2003 buick rendezvous with a crossover instead of aftermarket headunit. i have a 4 ga running the battery 0/1 ga for a ground and heavy duty rca's and remote wire. its a self install and wanted to know if there were any other problems like that with anybody else with the same amp or any similar bigger amps. the amp does have a frequency tuner on the back ranging from i believe 37Hz to 117Hz any answers or solutions will be appreciated
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
170
6
395
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
704
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
512
jdeezy410
jdeezy410
southeast MI
jdeezy410
