Amp Error on my head unit
  • 4
NDPTJB
CarAudio.com Recruit
I got a pioneer deh-s5010bt, i put an eq in my car the other day and after i it was installed i keep gettin amp errors not even 5 min after playing. I rewired the headunit and eq and it still keeps happening, i think something maybe wrong w the eq but idk just need sum help please. *it was after i added the eq before that i would play for hours a day without any amp error*
Most likely as amp error is referring to the internal amp ...usually it means it's getting a bad ohm load to low of impedance ..or detecting a bad wire ..pinched and sometimes grounding out ...I've seen this happen on aftermarket speakers where the speaker wire touches the body... or a bad speaker ..when it gets moving its changing the ohm load enough to go into protect getting an amp error.
I just looked up your deck and it has a nice built in 13 band EQ so take the aftermarket one out . You may be overloading the deck.
bro u know whats crazy, this happened to me to, i put a new set of 6.5 in the doors, and then luke it sounds good at idle then i drove it for about 5 min and it kept having a crackling sounds and static noises then everything turned off
A lot of times what happens when you put speakers in doors especially if mounting to metal ..and new screws ... the speakers will tweak a little moving especially with steel baskets and will rub the voice coils... sometimes loosening a screw adding spacers or even better build a thin baffle board to mount speaker too so everything is stiff and straight no basket flex
I wires the sub and checked it. It is at 2ohm and the speakers are at 2.5 from what the manual said
933
87
335
  • Locked
642
Amp
471
NDPTJB
NDPTJB
San Diego
Jeffdachef
    May 31, 2024
    May 24, 2024
