Amp Error on my head unit
NDPTJB
I got a pioneer deh-s5010bt, i put an eq in my car the other day and after i it was installed i keep gettin amp errors not even 5 min after playing. I rewired the headunit and eq and it still keeps happening, i think something maybe wrong w the eq but idk just need sum help please. *it was after i added the eq before that i would play for hours a day without any amp error*
Most likely as amp error is referring to the internal amp ...usually it means it's getting a bad ohm load to low of impedance ..or detecting a bad wire ..pinched and sometimes grounding out ...I've seen this happen on aftermarket speakers where the speaker wire touches the body... or a bad speaker ..when it gets moving its changing the ohm load enough to go into protect getting an amp error.
I just looked up your deck and it has a nice built in 13 band EQ so take the aftermarket one out . You may be overloading the deck.
bro u know whats crazy, this happened to me to, i put a new set of 6.5 in the doors, and then luke it sounds good at idle then i drove it for about 5 min and it kept having a crackling sounds and static noises then everything turned off
A lot of times what happens when you put speakers in doors especially if mounting to metal ..and new screws ... the speakers will tweak a little moving especially with steel baskets and will rub the voice coils... sometimes loosening a screw adding spacers or even better build a thin baffle board to mount speaker too so everything is stiff and straight no basket flex
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
308
452
  • Locked
741
Amp
541
NDPTJB
NDPTJB
San Diego
Jeffdachef
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
