Amp cutting in and out on different sub...
  • 5
Lonnie
6'6 White Giant
Ok this has got me at a loss.
I had 2 12" Type Rs and could run them from my AP15001d all day long without any issues at all. Now I got a 18" Custom Sacket sub thingy and my amp gets too hot and goes into protect.
My first thought was ground...but it did fine before the 18" so why the change now? Guess I could try grounding to somewhere else...BUT im limited on where I can ground it at. The hole for the wire terminal is kinda small.
No dont own one.
Also to resay what I said. It plays out fine unless I try to turn it up to max..then the amp keeps cutting to protect and back to normal.
No dont own one.
Sounds like a ground issue, or an impedance issue. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Did you alter any settings on the amp for the new sub?
gain set well below "Normal" and base boost is off completely
15
145
375
  • Locked
679
Lonnie
6'6 White Giant
Lonnie
Paducah, Kentucky
KnockTurnAL
maylar
    Jun 2, 2024
    Jun 1, 2024
