AM reception help!!!!!!!!
  • 4
stebbs919
7
philly
Hey everyone, i'm new to this site and figured someone here could help me out. I have a 2007 Hyundai Tiburon, and just recently got my windows tinted. The issue I'm having is that my rear window has the antenna in it and now I get no reception at all for AM stations. FM is fine though. I have an aftermarket head unit with a plug in the back labeled ANT. I'm sure I could get an antenna to run but I don't want anything big, maybe something like my satillite radio antenna that is a little box. Can anyone point me in the right direction. Thanx alot guys!!
I knew that, and wasn't thinking when I got it done. I'm not an audio guy at all, so the thought never crossed my mind!! Can a run another antenna
You could, but it would look pretty tacky. Definitely wouldn't fit with the looks of your car.
You could re-tint your rear windows with nonmetallic tint.
I didn't know anyone ever listened to AM radio.....I thought that went out with the 8 track tapes years ago //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
hahaha well in philly if u listen to sports talk radio you have to listen to AM
i work from 8am till 10 pm 4 days a week. no espn in between so it does the trick on the 45min car ride to work!!! that and i luv to hear the weirdos that take sports way to seriously!!!
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
I know this must be a simple fix! But can't work it out! When the head unit is out of the cage/holder the radio and DAB reception is perfect. As...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
174
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
458
stebbs919
stebbs919
philly
stebbs919
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
