Advise with wiring eight 4ohm loads
  • 3
That's a nice amp, and you should be fine without those rf crossovers. You can set a high pass for the tweets at 4k or wherever and bandpass the mid at 4k higher or wherever and like 80-100 hz lower.
oh i think i understand now.. lol
I can run the 4 tweets in series parallel to channel 1/2
and the mids in series parallel to 3/4?
Ahh makes sense something just clicked ..hope i didnt break anything haha
thanks a bunch buck!
No problem. As far as wiring
channel 1: 2 tweets in parallel
channel 2: 2 tweets in parallel
channel 3: 2 mids in parallel
channel 4: 2 mdis in parallel
As simple as that.
thanks!
you helped a young noob gain alot of knowledge //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You gotta start somewhere. You can email/pm me if you need anymore help. I install too so I know a few tricks //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
433
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
187
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
595
x91evo
x91evo
Chicago IL
Buck
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
