Hyundai Santa Fe 2012 OEM Infinity Radio to replacing Hyundai 2010 OEM Hyundai Santa
  • 3
I have a Hyundai Santa Fe 2010 and I am trying to install an Hyundai Santa Fe OEM 2012 Infinity Radio into my truck
I understand that Infinity Radio require an infinity amplifier and there might be some wiring requirements.
My questions are
Is there a way to connect a wire harness to my 2012 Infinity radio?
Can I buy and install a infinity amp will that work?
I am pretty sure that you will need a new type or wiring harness for the infinity radio. Believe me this is going to be a large undertaking. I think you will have less work and more quality if you just go with something after market. But if you want to streamline and make everything look stock, I recomend getting on a vehicle specific forum because I would guess your going to need to run a few new wire harnesses for the correct plugs and power connections for that HU and amp
short answer, no.
all of the wiring is likely to be very specific. besides the OEM infinity amplifier from a 2012 Santa Fe with that option, you'll need the harness between the HU and amp, and then a harness from the amp to every speaker. the amount of effort for zero benefit is pointless. you can't just use any Infinity amplifier.
you will quickly exceed the cost of aftermarket.
Ya man.. No telling how long that will last. you do one are and the weakest point begins to fail sooner or later. Looking at CDT speakers,. They...
6
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
656
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
592
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
778
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
744
cyberavenger
cyberavenger
baltimore, md
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
