Advice for iPhone ipad centric setup
  • 1
xpusostomos
I've got an old classic car, with a din size hole down low near the gear shift and a massive gap between the centre console and the dash. My life is ipad iPhone centric, and I don't like learning all the complexities of some complex stereo, so it seems sensible to use the massive gap in the car to install ipad / iPhone mounts and make everything run by ipad / iPhone. But I do also have this din slot, so an option (or the obvious option ) is to install a din stereo with good iPhone integration, and install the ipad above that. Then at least I have basic stereo functionality if I take the ipad out, but generally I want to do everything via the ipad. I'm not overly fussed about having a CD slot.
Anyway, one thing I'm confused about with all the stereos that allow plugging your iphone into USB is whether they force you to play music through the stereo, by selecting everything through the crappy LED display, or whether you can play the music through the iPhone music app, and the stereo picks it up. I even read the manual for the Sony MEX-gs600bt, but it wasn't obvious to me what the answer is. I definitely want to play music through the ipad controls, preferably the inbuilt app, rather than some proprietary app. It would be a nice to have, to have 2 USB slots, so I could plug in a USB of music too, but that's not essential.
What din head unit would you recommend for this? Price doesn't matter within reason. I don't see any point getting anything super complicated, just for the reason I'm trying to push the complexity into the ipad, and something with (say) some massive pull out screen running android or something would miss the point.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
356
It also lowers the amps efficiency and raises the current draw.
5
467
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
618
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
756
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
xpusostomos
xpusostomos
Australia
xpusostomos
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
