Accessories interfering with my Subwoofer.?
  • 5
GoT_2B_BuMpN
CarAudio.com Recruit
So, I installed an aftermarket set of fog lights and when I turn them on I can " hear" the power through my subwoofer. That is the best way to describe it. Also I have a CB radio and when I key and let go of the mic up my sub hits hard. Can anyone point me in the right direction on what to check/ correct??
Noise can be introduced through RCA cables. Be sure to use high quality shielded cables and try to keep them away from any big power cables or possible sources of noise.
Also if your head unit is low quality or has an internal fault (such as the infamous pico-fuse issue in some Pioneers) that could be a point where noise is being introduced.
You could start by getting 20 feet of quality RCA run it to the amp just loose and see if the noise issues change right away or as you move the RCA closer or further away from different points in the vehicle. https://www.nadbl.org/index.php/event-calendar
You may need to look into getting at least a 30-40 amp relay installed also for the Lights and one for the CB may help. As stated.. make sure your ground connection is solid and secure for your amplifier
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
620
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
GoT_2B_BuMpN
GoT_2B_BuMpN
No Conway, New Hampshire
GoT_2B_BuMpN
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
