About engine oil............??
i forget which is which , but pretty much its the weight(thickness) of the oil , one is for in warmer weather , the others for colder i think
differnet weights of oil are for older higher milege cars . . . depending what kind of car and what u do in it u might look into synthetics to keep ur stuff lubed more when ur car is starting in the morning after sitting than regular oils
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
3K
Martin
Martin
NY
crakpotjoe
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
