Nice review. How hard is it to get all panels and all back on after buiding everything up like that?
It really is a nice writeup - thanks Kris for taking the time to do it.
There is almost always plenty of room for these materials but you have to take your time and think ahead. The floor is simple because the carpet has plenty of give to it, but it is always a good idea to test fit the trim panels as you go along to see what sort of space you have to work with and where all of the clips and screws need to go. You sort of figure out what is ideal and then have to make some compromises to deal with reality. One of the nice benefits of this is that the CCF/MLV combination fills up what was air space and the entire vehicle ends up feeling tighter than it did before.
A perfect example of compromise is the back wall in Kris's car. We wanted to use both CCF and MLV behind the entire thing but there wasn't space. We ended up using MLV everywhere and CCF only where the gaps were wide enough. This did a great job of blocking rear wheel and exhaust noise and the CCF got rid of the rattles. He still has some squeaks because of all of the plastic that he's going to track down. I think if the car was mine I'd pull out the plastic shelf/bin thing and replace it with a fiberglass sub enclosure.
Hmm, learned alot from this thread... I too, used to think to just put layer ontop of layer of deadener to get that classic "thunk" sound when closing your hatch/door.
Is there a difference between the two methods in bass heavy vehicles? I would think the more the better idea would come into play with 145+db vehicles atleast in the trunk/hatch areas.
That's an interesting question. As Kris suggested, there's no harm in going a little above 25% coverage and it might help under extreme conditions. You should keep that 25% goal in mind though. It's not a magic number, it's just an indication of where you are starting to waste your time and money.
An SPL competitor should be mechanically reinforcing the vehicle's panels before doing anything else. I'm working with a few competitors right now to develop solutions for their application, but what's right for them really isn't right for 99% of us. They can't waste a single dB with the vehicle parked - no matter if it's music or just sound energy. Most of us want to reduce road noise so we can hear what we're playing or just have some quiet while we're on the phone. Most of us don't want it to sound like we're driving a rattle can down the road. It's all about deciding what you want to accomplish and doing what makes sense to get you there.
The thing about the barrier (MLV in this case) is that it not only stops noise from getting in, it stops the sound you make inside the car from hitting the sheet metal with as much energy as it would have otherwise - works both ways.
