3 12" Skar EVLs or 2 15" Skar VXf?
  • 4
Flip792
CarAudio.com Newbie
Hi, I'm trying to decide what to buy. This will be going in my daily driver. A Ford crown vic. I listen to all kinds of music (rap, hip hop, classic rock, metal, rock, etc...) Either way I'm using a Skar RP 4500.1 amp. It's between 3 dual 2 ohm Skar 12" EVL or 2 dual 4 ohm Skar 15" VXF. I'm going to be using the recommended ported box specs Skar gives. For the 12s it's 2 ft³ at 32hz. For the 15s it's 3.25 ft³ at 32 hz. Any help will be greatly appreciated. Thanks.
It's not even close, VXF. I just modeled those boxes and EVL box is ridiculous. I've never seen such a bad graph for a manufacturer recommended box. To get the same curve as putting those EVL's in a 6 ft cu box you would need to put the VXF's in a 25 cu ft box. If you want a flat response the VXF box is almost spot on, I'd go a little bigger but the EVL's belong in a 3 cu ft box for a flat response and of course the 2 VXF are going to be twice as loud if the spl graph curves are evenly shaped. And yes I'm talking about ported box @ 32hz for both
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
668
11
993
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Flip792
CarAudio.com Newbie
Flip792
Hammond, IN
CrownVic07
