2x DC Audio Lvl 4s Dual 1 ohm Perfect Condition!
  • 6
f1mclarenagr
4SKN
220
Milwaukee
2x DC Lvl 4's 12" Dual 1 ohm.
No Trades!!
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8”OD semi cup progressive roll spider
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 1 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former
• Rubber magnet cover
Used for 6 months. Still in mint condition. Was powered by AQ2200 with 1000 watts going to each sub. Pics show the ohm load when with both coils in series. Not burnt at all!
On the underside of the gasket there is rope caulk residue. Only on the underside and you cannot see it when installed!
225 each shipped, insured and in DC audio box with foam.
Shipping included.
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
A Link would be very helpful. Id be interested in taking a look at some gear
253
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
366
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
f1mclarenagr
4SKN
f1mclarenagr
Milwaukee
f1mclarenagr
