2nd battery wiring? only run positive wire from the front ,or run positive and neg wire to rear battery?
  • 3
Jimg
CarAudio.com Regular
217
13
how are you guys running your 2nd battery setup?
1 Is it best to run a 0 g positive and negative 0 g wire from the front battery to the rear battery
2 or is it ok to just run a single line from the positive to the 2nd battery ,and just ground the rear battery to a spot in the rear
or 3 does it not matter either way
plan on running 2/0 welding cable
I just dealt with challenges stemming from my chassis not being a good ground (rubber engine mounts,etc) so If you don’t have a complete loop that includes a good chassis to frame ground your second battery voltage could (may not but could) suffer if you’re only running positive battery to battery. My remedy was front battery to frame ground and front battery to rear battery ground. Second battery to frame would be essentially the same as long as you already have solid front ground to frame. Cost me $20 run of 2/0 welding battery to battery and two extra lugs.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
Jimg
Jimg
BCotrell
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
