2nd Battery or HO Alternator
  • 3
cf29qa
Newbie to the forum here!!
I have a 99 Tahoe with stock alternator and Optima Red Top 9004-003 Battery. The system I plan on running is an 800 RMS amp and a 2500 RMS amp with 2 8" cooling fans. I have also have the Pioneer AVIC-Z150BH head unit. My question is if my current alternator and battery set up is sufficient enough or if i need to upgrade either of them. I have already done the big three upgrade as well. Thank you in advanced for you help.
You'll want a HO alt. Your truck should be easy to find something used really cheap, though. Depending on how your voltage does, you may want another AGM battery in the back.
if it feels like your truck is struggling to barely keeping up all the electrical demands, go with the high output but if you have like no headlight dimming or serious alternator noise than just get the extra battery. It might vary from vehicle but the 2nd battery made my system hit loud and long without loss of volume. I just threw in my high output afterwards because i had enough to buy it but it really felt like it was unnecessary after the H/O install.
I have not tried any Lith.Batteries yet. I am debating on that for Next years build out. deff considering
15
3K
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
cf29qa
cf29qa
United States
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
