2014 Accord Sport SQ Build keep_hope_alive
****, did they know you?
They didn't know me. Just kids walk into the neighborhood checking doors looking to see if anything's unlocked and if there's anything easy to steal. My garage door was unlocked because I was going inside for 2 minutes. The main garage door was closed. They're not kids from my neighborhood but about a quarter mile or half mile away that just happened to walk through the neighborhood. They had good timing to find a spare set of keys that 99% of the time live inside my house
Rich V.
Rich V.
Worst! Time for a fingerprint reader and ejection seat mod!
Rebuilding the doors. This time I am greatly increasing the sound absorption used.
Old fiberglass panels show no moisture issues after 2.5 years.
New install increases thickness
Adding a proper diffuser behind the speaker
Window clears
Sent from my SM-G900V using Tapatalk
Breaks up the rear wave from being directly reflected back to the cone, effectiveness is based on physical size due to relationship to wavelength
Thanks, that makes sense!
I like that. I used the FAST rings on my doors. Whats the material?
Closed cell foam weatherstripping is used for gaskets around the speaker and is $3 for 10'. The fiberglass ceiling tiles are $6 each for 2'x4'.
FAST rings don't offer much for sound absorption despite product claims. I have some I've tested with.
You know that you have gotten your speaker gasketing correct when you see a continuous circular imprint in the foam. That imprint is made by the plastic shroud that seals against the factory speaker.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
805
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
keep_hope_alive
    May 31, 2024
    May 24, 2024
