2012 F-150 door speakers not working
  • 2
freddieg80
i have a 2012 Ford F-150 XLT, no factory amplifier. The truck has a kenwood double din, Fosgate door speakers, factory tweeters. My issue is ALL 4 door speakers stopped working and only tweeters have sound. I put in a brand new double din I had and still the same, no sound out of all 4 doors.
I suggest you take a DMM, an hour or two, and do some troubleshooing to see what the issue is. No one will be able to tell you what the issue is, it could be no rca output, bad RCA's, a bad amp, bad wiring to the speakers, etc.
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
824
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
freddieg80
freddieg80
california
wew lad
