2012 F-150 door speakers not working
  • 2
freddieg80
CarAudio.com Newbie
i have a 2012 Ford F-150 XLT, no factory amplifier. The truck has a kenwood double din, Fosgate door speakers, factory tweeters. My issue is ALL 4 door speakers stopped working and only tweeters have sound. I put in a brand new double din I had and still the same, no sound out of all 4 doors.
I suggest you take a DMM, an hour or two, and do some troubleshooing to see what the issue is. No one will be able to tell you what the issue is, it could be no rca output, bad RCA's, a bad amp, bad wiring to the speakers, etc.
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
674
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
freddieg80
CarAudio.com Newbie
freddieg80
california
wew lad
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
