2 10s, 2ohm, 4ohm dvc or 8 ohm
  • 4
zam70
Wanting to buy 2 10" subwoofers. Needing 2ohm, 4ohm dvc, or 8 ohm (basically, I need to end up with a 2 ohm stereo or 4 ohm mono load)
Subwoofers also need to be fairly shallow, they are going under the back seat of an f150...so, under 6" mounting depth And enclosure will be appx .6ish each
SQ is my main concern, Looking for ID idq, ads, Boston etc...not really sure what some of the others would be...
Subs will be getting roughly about 250watts each.
No budget in mind but would like to stay reasonable.
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
zam70
zam70
Springfieldish, IL
surreal
    May 31, 2024
    May 24, 2024
