1999 ford escort lx speakers wiring diagram?
  • 2
if there is a common color at each speaker, it's probably the negative. or if it's a solid color and the same color with a black stripe, the striped one is negative. you should also be able to look at the old speaker or the clip for the old speaker and figure it out.
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
894
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
chris Boug
chris Boug
san francisco, ca
chris Boug
