1 sealed box or 2 vented?
me = confused
can't fit sealed enclosure (the smaller)
but can fit 2 vented (bigger) ones????????????????
That's like saying I can't eat a 10 Oz steak in one meal, but I can eat 30 pounds of ham
I think he's asking if he should do 1 sealed box for 2 15"s or 2 seperated ported boxes because he can fit in 1 ported box for both subs. and this is because the size of the trunk opening
****, so people actually build boxes with 2 subs sharing the same chamber? That's ****ing whack. Why wouldn't you make the box 2 chambers? All the multi-sub boxes i've had built or seen built for friends had separate chambers per sub...
Another benefit is that if you absolutely have to, you can cut one box off the other to make it fit in a smaller space without having to build a new box
Don't ask.
Twice the amount of space(AKA Resistance) AND the resistance of the other cone which is now acting like a passive radiator. I always try to chamber off my ported subs.However, if you do use two vented, make all the cuts in one day, and get it all together in one day. Any slight warping has the chance of being disastrous.
yeah i got the supplies, and i made a muach up of a daul ported cause i thought it would fit but it didnt so now i gotta get all new dims....some1 made my other dims. but isnt thier a website with all the calculaters on it ...woofer sumthin?
A 30"x16"x20" box is a LOT harder to fit into a trunk than a 15" x 8" x 10".
LOL @ your math
30" X 16" X 20" = 5.55 cubes gross
15" X 8" X 10" = 0.7 cubes gross
How the hell is 0.7 cubes half of 5.5 cubes????
You FAIL.
HARD
Btw, you just got schooled by a drunkie.....
LOL @ your math
You FAIL.
HARD
it would be half the width though...not half of all dims...just1
exactly
IDSKOT fails.......
You could always build the enclosure inside the trunk //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
exactly
IDSKOT fails.......
dont have a garage and its cold...but i think 2 sepreate will be better neways.
but whats the website that tell u how big the port size will be...itll be smaller than the port on the dual box
LOL @ your math
You FAIL.
HARD
4.4 cubes for the 30",
.4 cubes for the 15".
It wasn't made to be mathematically accurate. It was to show the difference.
Half would be 16x16x20, which is 2.2 cubes.
Sorry I didn't feel like actually doing the math because it was just for argument's sake.
15-18 in^3 per cubic foot
4.4 cubes for the 30", .4 cubes for the 15".
you arguement fell through, as 15 X 8 X 10 is not half of 30 X 16 X 20.
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
In terms of space inside, you're right. But in terms of physical dimensions, I was right. I don't know why you're on my case about not wanting to do the math to figure out what's half of the original hypothetical box measurements.
And OP:
Don't use that website... those are for DD drivers...
What Freq do you want it tuned to? I'll do the math for you.
And OP:
Didn't OP say he had DD drivers? Or are my eyes shuting down.....?
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
7
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
mccoy
mccoy
pikeville, ky
GAM3OVR
