Amp problem?
Jake2727
I have an amp and subs in my car. The amp power light blinks and subs stop working and it goes in and out when music is played. I made sure all the connections were solid, Checked fuses. Not sure where to go from here! Any recommendations?
Right now I have 4 Gauge powering the system.
Here’s some more details on the Amp:
  • each sub handles up to 500 watts RMS
  • 2-ohm total impedance
  • mono sub amplifier (500 watts RMS at 2 ohms)
I did not install this….. Truly have no idea what i’m doing.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
886
783
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
220
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
Jake2727
Jake2727
Venice, FL
    Jun 15, 2024
    Jun 15, 2024
