Speaker change in a Micra
  • 2
MicraMan
Hi. I am not new to the audio world, but yes I am in to the car audio, so there are some noob doubts I would like to talk with all of you.
My car is a Nissan Micra (K12 version), with 6'5" speakers, and my radio is a Sony DSX-A410BT (55WxChannel). The idea is to not have an amplifier, as I don't really need quantity, but quality, although it is always welcome.
I have read the first pages of the "Speakers FAQ", and probably I want a 2-ways component speaker. I have look to some speakers but they all are of much more Watts, like 120 or 200W, and I don't know if this would be bad for the radio or the perfomance, or would I be paying for more than what I can "enjoy" with my 55WxChannel radio.
And a very important question! Should all 6'5" speakers fit inside my doors? Worrying about the magnet size being too much, in some cases.
Also, can I mount bigger speakers than 6'5"? I have read there are brackets for different size speakers, but maybe they only work when placing a smaller speaker.
Any help would be welcomed!
Thanks
Bonjour Micraman, sache que la puissance d'un haut parleur ne changera normalement rien à une qualité ou à l'efficacité de l'autoradio, il n'a d'ailleurs aucun danger à installé des haut parleur plus puissant que la puissance de l' autoradio.
se qu'il va falloir regarder ces l'impédance de l'autoradio, normalement il es en 4hom, il faut que les haut-parleurs fassent 4hom.
vue que tu cherches de la qualité, je te conseille les focales ps165fe il sont un très bon rendement et il ristitue le son avec réalisme.
Thanks for the recomendattion, but this is way too much of what I want to spend.
Also, I have read the speakers shouldn't have a lot more watts than the radio/amplifier, and as I said, my radio have 17w, and those speakers seems to have 60-70w.
I am already looking at the impedance as a fundamental spec.
What do you think about what I said of the relation between radioVSspeakeras wattage?
Merci pour la recommandation, mais c'est beaucoup trop de ce que je veux dépenser.
De plus, j'ai lu que les haut-parleurs ne devraient pas avoir beaucoup plus de watts que la radio/amplificateur, et comme je l'ai dit, ma radio a 17w, et ces haut-parleurs semblent avoir 60-70w.
Je considère déjà l'impédance comme une spécification fondamentale.
Que pensez-vous de ce que j'ai dit de la relation entre la puissance radioVSspeakeras ?
the power of the speakers does not affect the car radio, you can install 300w or 15w speakers, it will not change anything
I recommend for a small budget this pair of speakers
457
436
582
492
MicraMan
MicraMan
Banyoles City
nolde216
