I need some help tuning my amps with a oscilloscope
The rca is suppose to have ~2 vac before clipping but my HU is only producing 0.2 vac clean before clipping.
Edit: there is coming sound out of the sub and speakers I just want to know how much I can tune it before it's clipping
You can also do the same test with a 0db sine wave, say 1khz or 2.5khz sine wave. Turn up the gain or volume, you'll hear the pitch of the sine wave change and that's clipping. When you hear the clipping, turn the gain down 2-3 db. If you have really good ears, you can turn it down just 1db.
Yeah but how will i tune my subwoofer?
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at say 50-60hz and turn the volume up on the radio until you here the pitch/tone of the sine wave change - it'll get higher, it may take on a more mechanical or harsh sound. That's clipping. Now you've identified where you can hear clipping from the HU pre-amps. Keep your volume 2,3 db below where you can hear clipping and you should be good. You should probably repeat the process a few times so your ears can become accustomed to what a clipped sine wave sounds like. There may be comparison tracks floating around on the internet to help your train your ears.
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
527
887
Snuskgamer
Snuskgamer
Sweden
Jimi77
