Need help with amp settings
Jeremysmith122703
So i have a 2018 chevy cruze lt stock HU with a skar 12"evl at 1 ohm in a ported sub zero box and a skar rp1200.1d amp right now i have bass eq at 0 gain is lil more then 3/4 up lpf all the way down and subsonic all the way down... it hits really hard even cracked the 3rd brake light only thing is i know its not hittin all the tones right and cant figure out wat to put those settings at... thanks for any help
Sounds like u need to turn your lpf up to at least 70 or 80 hz
Turn the log up a little
set your gain right, heres how. test tones are at the very bottom...
961
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Jeremysmith122703
Jeremysmith122703
Stockton,ca
nauc
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
