What amp do I need?
They are 8 ohm's each. So you could wire them in parallel down to 2.66 ohms, but keep in mind that will result in mono, (not sure if those horns are stereo or just mono (like a sub). So you would be looking for an amp that can do 450w @ 2.66ohms x 1ch.
Without doing the math again, I remember, 2.66ohms is right in the middle of 2 and 4 ohms. So if you want something that will do 450w at 2.66ohms on 1ch, Just about any amp that can do a combined 900w at 2 ohm and 4 ohm will do it. (i.e. if it will do 350w at 4ohms & 550w @ 2ohms, or 300w at 4 ohms, and 600w at 2 ohms, and it will work). You can always go higher and turn down the amp.
961
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Darro148
Darro148
new York
HardofWhoring
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
