Speakers pop then head unit resets?
  • 2
doogievlg
Haven’t turned on my audio in the car for a few years due to other projects. Today I decided to give it a shot after wiring up some new gauges. I turned on the radio and got a loud pop from the speakers then the unit reset. Tried it with USB and got the same results. When I am cycling through the source menu the beeps come though the speakers as normal.
Should also add that the speakers are Alpines that are approaching 20 years old and the Sony head unit is probably 10 years old. I plan on replacing the unit and speakers but I don’t want to face the same problems when I am done.
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
987
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
251
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
202
doogievlg
doogievlg
cincinnati
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
