Audio quiet after amp install
acoleman99
I have a problem with my car audio being quieter after i installed a 5 channel amp to power 4 door speakers and 1 sub. I am only using one hi level input for the signal tapping into the rear left speaker output coming from the factory headunit. Is this the cause of bad quality and quiet levels?
You have to use left and right signals, otherwise the amp will only amplify half the radio's output. Also check the Gain setting.
A Link would be very helpful. Id be interested in taking a look at some gear
202
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
328
acoleman99
acoleman99
Jacksonville, FL
acoleman99
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
