21 Kia seltos wiring inquiry
  • 2
BrentJones
21 Kia Seltos
Objective - Change the 4 stock speakers, add 2 amps, and sub. Would like to use the factory wiring harness’ in the doors to the speakers. Tap in to the main harness inside the cabin to run to the converter>amps>then back.
Inquiry - The front door speakers are set up in a component array with a mid woofer and satellite tweeter. The wiring to both speakers in the front left door are identical, both orange and green. I am wanting to eliminate the tweeter and run a 2-way speaker. Is there a crossover network somewhere up the line that I need to account for? Or are there resistors on the individual speakers controlling the frequency output? I am just starting the project and looking to minimize cutting open the main wire harness as much as possible.
Thank you for your time and advice.
21 Kia Seltos
Check out this business, (PAC – Connecting cars and technology. Your total installation solution. (pac-audio.com) ) as they specialize in wiring harnesses to allow you to plug into the OEM wiring harness and add separate amplifiers. (You can daisy chain the amplifiers.) I used them several years ago to add an amplifier for subwoofers.
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
You could crimp spade terminals onto the new wires and insert them into the speaker harness.
Hello, I just installed a Chinese Headunit and wondering for the Steering Wheel Controls if i need something else or if it should work.. On some...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
177
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
582
BrentJones
BrentJones
Colorado Springs
huberoy123
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
