Headunit sounds like its under water.... andriod
  • 2
what ^ said. amp gain setting info, test tones are at the very bottom...
601
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
Ali2627
Junior Member
Ali2627
Los Angeles,ca
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
