GCON 18" SSA (Infinite Baffle?)
  • 6
Jake321
96
14
Hawaii
Can this thing do infinite baffle?
What is the QTS requirement for infinite baffle?
Is there any other T/S Specs that interplay?
"GCON 18" 950W Subwoofer by SSA"
"T/S Specs:
D4 / D2
Fs. 25.5 / 24.9 hz
Re 8.0 / 4.0 ohms
Qms 6.49
Qes 0.82 / 0.78
Qts 0.78 / 0.74
Cms 0.14 mm/N
Mms 304.5 / 306.5 gr
Bl 16.3 N/A
SPL 93.1 / 93.8 dB
VAS 178.0 L
SD 1210cm^2
Xmax 23mm
RMS 950 watts
SSA GCON enclosure info:
Overall Diameter 18.5"
Displacement 0.19 Cu. Ft.
Cut out 16.75"
Mounting Depth 9.5"
Sealed: 4.25-4.75ft^3
Ported: 6.5-7.5ft^3 @ 27-34hz w/15.25^2 of port per cube"
10x Vas is the minimum for a true infinite baffle setup. My current substage and my last 5(maybe 6 or 7, hard to remember) substages have been IB, and I don't believe any of them were "ideal" subs in the QTS department. My current sub(s) have a qts of .245 and a Fs of 26.5, which is very far from the ideal range of .650-.750 Qts.
I believe the Gcon would sound great in IB. Be careful with the power, and have a bit of EQ available and you should be fine.
Matt
Looks like a good candidate. Keep your power under 500 watts.
Just a heads up. I have used subs with a qts of .47 with success.
Is this 718 capable of IB?
Speaker Size (In):18
Watts RMS:600 - 1200
Watts Peak:3600
Impedance D2 / D4
VCD (In):3
Piston Diameter (In):15 1/2
Fs (Hz):26.92
Qms:6.79
Qes:0.567
Qts:0.523
Vas:170.4
Xmech (MM):80
Xmax (MM):16
Frame OD (In):18 3/8
Frame OD w/Gasket (In):18 1/2
Mounting Diameter (In):16 5/8
Mounting Depth (In):10 1/2
Motor Diameter (In):7 3/4
Motor Depth (In):3 1/2
Woofer Displacement (CuFt):0.25
Ported Enclosure (CuFt):6.0 - 8.0
Shipping Weight (Lbs):43
Price (USD):559
Watts Peak:3600
Impedance D2 / D4
VCD (In):3
Fs (Hz):26.92
Qms:6.79
Qes:0.567
Qts:0.523
Vas:170.4
Xmech (MM):80
Xmax (MM):16
Price (USD):559
What sub is this?
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
Jake321
Jake321
Hawaii
Jimi77
    May 31, 2024
    May 24, 2024
