djdilliodon!
I donāt think most want to go through 11 pages on the original thread so Iāll do a new thread for this. Little refresh, taramps smart 5k, 3.75 cubic feet each 15ā tuned to 31-32 hz. Subs at rest sit at 2 ohm so I know I aināt seeing fully power. Car is at idle so voltage drops to 13.3 volts. Box was built outside the car and put in the back seat area, bolted down, and a top trim plate added to make it like a wall. Sides do have gaps about 4ā wide so itās not totally sealed off from the trunk. Subs and amp I was playing for over 2 hours before metering so things are running a bit hot (will meter again when everything is nice and cool). The result? 150.6 on the glass @ 40 hz. Did get a 150.7 letting everything sit for 20 min and doing it again but didnāt take a pic. Now Iām getting curious to see actual power the subs are seeing! I should of did the coils in D1 but ran out at the time as I was impatient
. Wish I also made the box to 4.25 cubes per sub but would of required building the box inside the car and my old azz aināt doing that
. Iāll get a truck next when this beater is toast!
![š š](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f602.png)
