Skar amp hookup
  • 2
GB1978
I've got a 2022 Volkswagen GTI with a stock head unit. I'm installing a Skar amp and subs using a LOC. I hooked up everything last night and forgot about the REM wire. I ran it on the outside of the car just to the LOC just to make sure it worked. It did, so I fished it through its permanent home and hooked it back up. I had power to the amp again until I plugged the harness into the head unit. I lose power every time I plug the head unit back in. Anyone have an idea what would cause this?
999
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
GB1978
GB1978
Green Bay, Wi
