Parallel 6th order/RDS 6.5
SlugButter
CarAudio.com VIP
4,664
2,147
arizona
Going in a Ford Escape. For a little extra bump in his work vehicle, easily movable and tools can get piled on top without damage to the sub.
Box is .5 cubes tuned to 35 HZ and .2 cubes tuned to 64 HZ. Mainly metal and rock listener with occasional older 90s rap. RDS audio 6.5 inch sub. 400 watts RMS
I like the rds stuff, Rick has built up the line and the 6.5 are lil monsters if enclosed right. I've a bit of experience designing for those particular subs.
They seem to do pretty good in .5 tuned to 35 hz or so. This is the first generation. I pulled it from a box that had 4 of these in it, 3 of them blown. This was the lone survivor. My first time using anything from RDS. It feels nice. I might buy one for myself. It's a heavy little sucker.
They're hi ebp subs, tuning them 36hz in .4ft3 with 6.5in2 of port seems to let them open up, in a 6th?
I'd probably try for a 1:1 or close and ignore modeling software. Sooo peaky no matter how you model it with a 6th. Remember cabin gain is any part of the result. I've had great luck designing ported for those. Ive yet to try a 4th because of the reverse ratio and ebp but a 6th is doable. Given the ratios are on point.
Design for what the sub likes... Dont force it.
Well, they don't sell the CDTs so there is that... I sold electronics (audio) years ago, in a very hi-end environment. one of the emphasis they...
If you want to do this I'd suggest you buy one of those PAC or Audiopipe 3 way passive crossovers off Amazon to split the signal between the three...
SlugButter
CarAudio.com VIP
SlugButter
arizona
SlugButter
    May 31, 2024
    May 24, 2024
