Have power but no sound
Just got finished installing a new double din head unit in my 99 mustang GT, i have power and the unit itself works but i am not getting any sound out of the speakers, what should i do?
Yes, i used the harnesses i got through crutchfield and i also used their service which wires the harness up. And as far as i know the factory amp is still there due to the plugs still being there
Have you checked the fuse at the fuse panel labeled for the onboard amplifier? Could be a blown fuse for the existing amplifier? Id check that first.
#2- May hit the RESET on the HU to see if that may help, and read on the HU to see if there is a setting that may not have been enabled after the RESET
Sometimes you need to turn off the internal amplifier on the head units if you are using a OEM amplifier wiring harness and leaving that oem amp in. Might want to check in the settings area and if it has that option turn it off. Manual should show you how to do that.
Thanks, ill try that too
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake...
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
418
672
jakedasnayk
jakedasnayk
TEXAS
jakedasnayk
    May 24, 2024
    May 23, 2024
