Install accessories
AnthonyO
Budget Banger Connoisseur
Looking for:
0 gauge inline fuse holder
0 gauge copper lugs (Crimpable)
0 gauge firewall grommet
0/4 gauge disribution block (fused) 0 gauge in/ 4 gauge out
0/4 gauge grounding block 0 gauge in / 4 gauge out
Just trying to see whats out there before I buy online. Hopefully someone has some stuff they don't need and wanna make a little cash
Flat rate padded envelope should be your friend
Let me know if you find grommets, kinda hard to find for me.
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
754
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
952
AnthonyO
AnthonyO
Minot, North Dakota, United States
wew lad
    Apr 26, 2024
    Apr 26, 2024
